wncbw7 Posted March 29, 2017 Share Posted March 29, 2017 See attached image. I am trying to apply a siding or rustic wood material to the vaulted ceiling. Would like it to run parallel with the rafters, however it pieces itself some parallel and some the other direction. Have this issue on two projects. Any suggestions on how to force the siding to run vertical? I have changed its angle in the texture dialog box. ceiling 3-29-17.pdf Link to comment Share on other sites More sharing options...
wncbw7 Posted March 29, 2017 Author Share Posted March 29, 2017 Eric, thats what I did to get the pattern vertical to begin with. However when I apply it it will some times be vertical and some times not. and then if I color it it will sometimes switch directions. Link to comment Share on other sites More sharing options...
