cooksbay Posted October 13, 2016 Share Posted October 13, 2016 I'm using Chief Lite X5 and am having problems I haven't had before. The dimension default is set to the outside of the wall sheathing line. It seems to be having a hard time finding the dimension layer. Odd fractions are appearing and I have to look at each one to see were it is dimensioning to. If I try to move a wall to adjust the dimension to where it should be it throws something else off. It dosen't happen on everything, just on some dimensions. Any suggestions? Link to comment Share on other sites More sharing options...
