CTB_Russ Posted September 10, 2016 Share Posted September 10, 2016 I have used this method to create belly bands and stone sills on other plans without any trouble. on the plan I am working on (created in X6 now in X8) I can see the moulding polyline in plan view but cannot see the polyline in the overview...What am I missing here? Link to comment Share on other sites More sharing options...
CTB_Russ Posted September 10, 2016 Author Share Posted September 10, 2016 Posting the plan file will get the best suggestions. Try making the molding very large -- 12"x12" for example. It's probably not where you think it is. Check elevation, inside or outside of polyline etc. I have tried to over size the moulding...change height...checked to see if moldings were turned on..pulled the polyline away from the wall...nothing Link to comment Share on other sites More sharing options...
Solution CTB_Russ Posted September 10, 2016 Author Solution Share Posted September 10, 2016 ok so....i figured out that the moulding layer was not toggled on in the overview window...Geez Link to comment Share on other sites More sharing options...
