Dynamic Extension Lines
Kmac7476
When I create a Dimension string then move it away from the building, it does not extend the Extension Lines. I have to lengthen them manually which obviously takes a lot of time in a house layout. I know Chief is supposed to extend the Extension Lines as you drag it so I obviously did something wrong at some point. I need to get that turned back on.
