wkenddad Posted July 30, 2025 Share Posted July 30, 2025 I would think that there was better text editing. Usually a text editor with a ruler which can include Tabs and Indents would be nice. I would like to have hanging indents to format some of my text. Example: M-1 Domestic clothes dryer moisture exhaust ducts shall terminate on the outside of the building and shall be equipped with a back-draft damper. Sheet metal screws or other fasteners that will obstruct the flow shall not be Unless otherwise permitted or required by the dryer manufacturer’s installation instructions and by the building official, domestic dryer moisture exhaust ducts shall not exceed a total combined horizontal and vertical length of 14 feet including two 90° elbows. Two feet shall be deducted for each 90° elbow in excess of two. 2022 CMC, Section 504.4. M-2 Make up air. When a closet is designed for the installation of a clothes dryer, a minimum opening of 100 square inches for makeup air shall be provided in the door or by other approved means. 2022 CMC, Section 504.4.1. M-3 Installation of a Listed Cooking Appliance or Microwave Oven above a Listed Cooking Appliance. The installation of a listed cooking appliance or microwave oven over a listed cooking appliance shall conform to the conditions of the upper appliance’s listing and the manufacturers’ installation instructions. 2022 CMC, Section 921.4 M-4 Domestic range vents. Ducts for domestic kitchen downdraft grill-range ventilation shall be installed as per 2022 CMC, Section 504.2. But would like it to look like this: M-1 Domestic clothes dryer moisture exhaust ducts shall terminate on the outside of the building and shall be equipped with a back-draft damper. Sheet metal screws or other fasteners that will obstruct the flow shall not be Unless otherwise permitted or required by the dryer manufacturer’s installation instructions and by the building official, domestic dryer moisture exhaust ducts shall not exceed a total combined horizontal and vertical length of 14 feet including two 90° elbows. Two feet shall be deducted for each 90° elbow in excess of two. 2022 CMC, Section 504.4. M-2 Make up air. When a closet is designed for the installation of a clothes dryer, a minimum opening of 100 square inches for makeup air shall be provided in the door or by other approved means. 2022 CMC, Section 504.4.1. M-3 Installation of a Listed Cooking Appliance or Microwave Oven above a Listed Cooking Appliance. The installation of a listed cooking appliance or microwave oven over a listed cooking appliance shall conform to the conditions of the upper appliance’s listing and the manufacturers’ installation instructions. 2022 CMC, Section 921.4 M-4 Domestic range vents. Ducts for domestic kitchen downdraft grill-range ventilation shall be installed as per 2022 CMC, Section 504.2. Also is it possible to add suffixes and prefixes to dimensions? For example a dimension of distance could have teh suffix of [12-'0" O.C.] where the O.C. is the suffix Am I missing something? Link to comment Share on other sites More sharing options...
