HELP!! Floor finish not visible on basement floor
LatelierDesign
Hi y'all !
So, I tried a lot of different things but I can't figure out why the floor is not visible in the basement = 3d view.
It's just all white. I clicked each room and made sure there's a floor thickness is not at 0 (right now i put 2")
I attached the various windows / dialog box so hopefully someone could help me with this.
I don't know if it's just a glitch as sometime the pony wall doesn't work too and when it works, the glass part doesn't show (it shows as plain painted wall - even if it says glass - standard or tempered in the dialog box) and when I click on the upper part of the wall to make it as glass it loads for a few seconds and shut down.
I use the 2020 version.
Thank you for your time and assistance.
  • LatelierDesign changed the title to HELP!! Floor finish not visible on basement floor
