BrentJohnJohn Posted March 19 Share Posted March 19 Greetings, I have been trying to figure this out for the past 2 hours and am not having any luck. For some reason, the foundation is not aligning correctly. However, the wall is one continuous wall – red line. Any help will be greatly appreciated. Link to comment Share on other sites More sharing options...
Solution BrentJohnJohn Posted March 19 Author Solution Share Posted March 19 Greetings, I finally figured out the issue: I had a short wall on a unchecked layer that was causing the problem. Link to comment Share on other sites More sharing options...
