kevinman4404 Posted January 24, 2025 Share Posted January 24, 2025 Hi, I am not having any luck finding a way to create a certain type of roof in Chief Architect. It is basically a square folded in half diagonally, leaning on one side with the 4th corner raised up so that it forms a straight folded line. It's raising the 4th corner that I am having a hard time with. I have illustrated what I mean with a piece of tin foil as well as an example from a house (with two such roofs). Would anyone have any leads on how to achieve that? Thank you Link to comment Share on other sites More sharing options...
kevinman4404 Posted January 24, 2025 Author Share Posted January 24, 2025 Yes, that's what I'm hoping to achieve. How did you do that? I am not sure how to raise the corner wall except manually/informally dragging it (locked to Z axis), and them I'm not sure how to either get the roof to follow the wall, draw the roof planes on top, or drag the roof corner (locked to the Z axis). Or is it something that can only be done using 3d objects? (Chief Architext X14) Link to comment Share on other sites More sharing options...
kevinman4404 Posted January 24, 2025 Author Share Posted January 24, 2025 Join the two planes on one side and extend it. Then I guess adjust either the pitch or the corner wall height until they meet. Thank you, it was so simple! Link to comment Share on other sites More sharing options...
