Change roof height over just garage
Kanomis
Hello all,
I swear in the past I have been able to change the room height of one room without changing the height of others. Either way, I need to raise the garage height and roof together without affecting the rest of the main floor. But whenever I change the garage height, the rest of the house changes with it. Is there an option somewhere to turn this off? I have assigned basic interior rooms, including the garage.
I have tried manually adjusting the height of the garage walls, but this just pushes the walls through the roof.
Walls sticking through roof.
All the walls raising when I change the garage room height...
Thank you so much for taking a look at this! Totally solved my problem! Was just that little nook in the garage.
Yeah, I tried making a second roof group hoping that would do it, but to no avail.
And thank you for the tips on using defaults. Very insightful!
