jgolden Posted January 24, 2024 Share Posted January 24, 2024 Greetings, Version: Home Designer Pro 2024 I have a defined pony wall for a walk out basement and set the components for the default pony wall. When created on floor 0, it only lists the insulation items in the upper wall. It lists all items correctly on floor 1. Is this expected? If so, is there a configuration item I can't locate that will change the behavior? Thanks, Joel Link to comment Share on other sites More sharing options...
