Steve_Nyhof Posted January 22, 2024 Share Posted January 22, 2024 I rarely draw monoslab footings so I am not the expert on this. I was helping Larry Belk (https://www.larrybelk.com/) with some optional ways to pull off mono slabs with CA using Stem Walls and Footings, mainly on the wall design where your footing is poured first and is used as the brick ledge. The bottom two videos are a way to make the wall in section view look like a monoslab. Ignore my offset cursor, I was using a video app that I have since moved away from because of this issue. The Yellow circle is at the correct location. Section idea detail by Larry Belk Mono Slab with Stem Wall using Footing Ledge https://my-plan.stevenyhofdesigns.com/v/HAW98BrXWHD1j2Mm0ZQF Section idea by Larry Belk Mono Slab using Stem Wall and 4" Ledge https://my-plan.stevenyhofdesigns.com/v/vzBeuNHWADnGIlpfIilf Mono Slab using Stem Wall and 1.5" Ledge https://my-plan.stevenyhofdesigns.com/v/YVNuUZ3AdseRG0ThHfCs 1 Link to comment Share on other sites More sharing options...
