Missing Wall Details
moreauj
I have a few walls which don't show up as wall details in the project Browser.
No auto label either, although they do show up in a wall schedule.
In plan view with the Wall Framing layer on, I see the ends of all the studs.
In a clipped cross-section, the framing looks perfect, but no associated wall detail.
Seems localized to three of 4 walls that form an elevator shaft on 1st and 2nd floor.
The upper floor is Clear Below.
It is surrounded on three sides by a stairwell which is also Clear Below on the upper floor.
Both share a common front wall that generates a Wall Detail just fine.
As this seemed suspicious, three walls with open below surrounded by open below,
I temporarily changed all to Utility but still no Wall Details or labels.
Any suggestions?
Regards
Solved,  Seems Open Below defaults the walls to balloon through.
I guess as wall details are organized by floor, CA can't generate a wall detail for ballooned through walls?
Changed the walls to stop at ceiling and stop at floor and all seems well.
