Changing an Existing T&G from Fir to Oak
Drew-PRH
Good day all,
I thought I had seen somewhere where for example:
If you have an existing library item such as Fir Tongue and Groove (under Clopay) -
Referenced Files\Clopay.zip#zip:FirPlank_CAAB.jpg
One is able to change it from Fir to another species such as Oak.
I was going to use this Oak which may be close enough for the client to visualize -
Referenced Files\Andersen.zip#zip:Oak-White2r(30)
Not sure if this can really be done - OR what is the simplest way to archive a horizontal 6" T&G look to tie in the pre-made Hood Vent from Dura-Supreme
Thank you :)
