Upper Wall Won't Fully Remove or Delete
Drew-PRH
Good day,
For some reason I can not figure out, a small section of wall has been created at the lower end of a stairwell, close to the bottom (last) tread.
I've selected both from plan view and 3d to delete.
Anyway after removing the small bump-out wall it leaves a ceiling which I can not seem to click and adjust and it applies no drywall to that area of ceiling.
May be after the ceiling below is remove it will allow the drywall to apply to the ceiling????
Some images are below.
Also, I know it is easier for some to just open the plan and look - totally get it - I've tried to remove a variety of items to get the plan to 14mb, but not successful.
Yes I know the light does not need to be there - it just is.
So I uploaded a backup zip file to my site which can be downloaded here:
https://www.pacificridgellc.com/images/chief/09-11-23_Dining_Attic_Wall.zip
It is 26mb.  So I've only been using chief just over 1yr so I am sure there are other ways to get a 3-story plan smaller.
Thank you for your assistance and insight in advance! - :)
