Exterior wall surface
nsheppard
Go to solution Solved by nsheppard,
I cannot get this exterior wall between the 2 gables to change to brick. I have attached a picture of it, along with the opened specifications of that wall. You can see that it is showing brick below the gable, but not above. Any suggestions on what I can do to correct this? I know it is most likely a setting I have wrong, but cant determine what.
