dougdoan Posted February 1, 2023 Share Posted February 1, 2023 Hello, I have a 2-story structure where the 2nd floor will function as an attic with exposed ceiling. The ceiling height is set at 8" but due to the 8/12 roof, there will actually be quite a lot of usable clearance. However, in designing the stairs, I can't get the glass panel railing to look right. Setting Ceiling Platform to automatic cuts the railing off at 8" off the floor. Setting it to balloon through ceiling above sorta does the trick, but then the glass panel sticks out the roof. How can I get the railing to cut off at the ceiling/wall but not have the glass pane stick out the roof? Link to comment Share on other sites More sharing options...
