Missing Toolbars
Steve_Nyhof
I ran into this once before, where I open my CA and there are no toolbars on the top and side.
I found that my saved configuration was missing so I added it back in and set it default [ Switch To ]
Nothing happens.
I even reset my toolbars and still nothing.
Any idea how to get my toolbars back?
Thank you,
Steve
Ok, just to finish this... Resolved
I called Support and they had me click on the View > Toolbars button. And that worked.
However, for the record, that is the first thing I tried when I first ran into the issue, and nothing happened. But I did not check this button after I reset my toolbar in the Configuration - shown above on the first post.
To conclude, after setting the Active Configuration that you want to use, make sure to go back and click on the View > Toolbars button to make sure it is active :)
Thank you,
Steve
