I'm working on a 4 unit and 5 unit condo project.
After spending forever and a half adjusting the ceiling heights for the stepped units. I'm now having a hard time getting Chief to understand that they are "separate buildings". I just want the total areas, and the schedules to think of each unit as separate buildings. Right now it groups the entire floor area. Is there anyway to do this? Some way I can get Chief to see the individual units as separate buildings? Or am I whistlin dixie?
There are several ways, many of which have already been mentioned directly or alluded to. One that hasn't been mentioned though is to simply use a Custom Schedule. Just make sure all rooms in any given unit are set to report to a Schedule using a Custom Schedule Category and then set your schedule to report only that one Category. Make sure your schedules for each unit are set to report a Totals Row and there you have it. In fact, if you set your Schedule to Swap Rows/Columns and then Right
