KristjanM Posted July 7, 2022 Share Posted July 7, 2022 I have a foundation corner which doesn't seem to display correctly (for what I want). 8' tall wall meets a 2' tall wall at a corner. In the plan view, I want to see the tall wall but not the short wall which is under a patio slab. If i put the short wall on a separate layer and turn it off in the plan view, the tall wall shortens. If I look at the walls in 3D, the tall wall doesn't shorten when I turn off the short wall. There doesn't seem to be any way (that I can discover) to keep the tall wall at it's correct length in 2D. Any suggestions?Foundation Corner Visibility.plan Foundation Corner Visibility.zip Link to comment Share on other sites More sharing options...
KristjanM Posted July 7, 2022 Author Share Posted July 7, 2022 Eric, Thanks for your quick and simple solution. That's an easy fix. Link to comment Share on other sites More sharing options...
