ccollin Posted June 7, 2022 Share Posted June 7, 2022 I've been trying to figure out how to select the marker on a point to point dimension so I can resize it specifically to the length I need. Any video I've seen shows to select the dimension line and hit the "tab" key in order to move from the dimension line to the next object marker. However, when I do this it just selects the next object in the plan or, if I'm outside of the plan, doesn't select anything. Scratching my head. Any suggestions welcome. Thanks! Link to comment Share on other sites More sharing options...
