DenisePac Posted November 14, 2021 Share Posted November 14, 2021 Hi, I generated the roof for the attached drawing using auto-build roof. Can anyone help explain why my roof plane baselines are defaulting to the inside of walls (baseline height of 119") instead of outside of wall (baseline height of 113 11/16") like normal? As a result, the roof planes show "N/A" for Top of Plate. I have some manual roof work and correcting to do, but wanted to show it to you with auto-build still active so you can see what might be causing this. Top of plate is 9' and the primary roof pitch is 10:12. Thanks TestHouse.zip Link to comment Share on other sites More sharing options...
DenisePac Posted November 14, 2021 Author Share Posted November 14, 2021 Ah. Thank you Eric. I will look this section up in the manual and review it all. Link to comment Share on other sites More sharing options...
