karen1 Posted December 3, 2014 Share Posted December 3, 2014 Can someone please tell me how to export 3D dwg files? Link to comment Share on other sites More sharing options...
RodCole Posted December 3, 2014 Share Posted December 3, 2014 From the floor plan view select the Orthographic View Tools icon. Next select the Orthographic Full Overview camera icon. This will bring up a full overview of the model based on the layerset assigned in camera defaults. If the correct layers are not displayed, then make whatever changes are req'd so that the items you want to export are visible on you screen. Select File, Export, Export 3D Model (DWG,DXF) then select the options you want from the dbx "dialog box" that appears. I have found that the 3DS file format works quite a bit better than the DWG format for many 3D objects. Hope that is helpful. Link to comment Share on other sites More sharing options...
