Linnukas Posted November 23, 2020 Share Posted November 23, 2020 Hi! I am struggling to change the height of my bay window. The problem might be that it is in "open below" area and I'd like the window to be higher than the floor ceiling level. Does anyone know how to solve this issue? Here's a picture. Thanks in advance. Link to comment Share on other sites More sharing options...
Linnukas Posted November 23, 2020 Author Share Posted November 23, 2020 4 minutes ago, solver said: Don't use the Bay Window tool. So You are suggesting that I do it manually? Link to comment Share on other sites More sharing options...
Linnukas Posted November 23, 2020 Author Share Posted November 23, 2020 1 minute ago, solver said: Exactly. You could also remove the 2nd floor above this room and make the first floor ceiling higher. Will need to deal with the windows when using the bay window tool. From your image you probably do not want a single wide window, but rather multiple windows which cannot be done. Thank You very much! Link to comment Share on other sites More sharing options...
