Steve_Nyhof Posted July 29, 2020 Share Posted July 29, 2020 On the wall schedule there is a Description on the right - by default. Where is this value located so I can modify it for each wall type? Thank you Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 29, 2020 Author Share Posted July 29, 2020 Thank you - I did find that description. However, I have numerous exterior wall types. Is there a way to give a description to each of my wall types in my User folders? When I update the defaults, it keeps my last change only. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 29, 2020 Author Share Posted July 29, 2020 Ah! I found it Link to comment Share on other sites More sharing options...
DarlingInc Posted November 11, 2020 Share Posted November 11, 2020 I'm having the same issue...Can you post how you found the solution? Thank you! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 11, 2020 Author Share Posted November 11, 2020 Hello, here is a video that will show you some detail about walls... https://www.loom.com/share/cd8e2c56be0142b8af16d1d53b0a0faf Link to comment Share on other sites More sharing options...
DarlingInc Posted November 11, 2020 Share Posted November 11, 2020 Steven you ROCK!! Much appreciated. I could not for the life of me figure it out. Thank you! Natalia 1 Link to comment Share on other sites More sharing options...
