xtal_01 Posted June 3, 2020 Share Posted June 3, 2020 Hello, I have a two part question ... 1) how can I ... or can I ... have a custom alignment of my main wall above my pony wall? I have a 2 x 6 wall on top of 4" blocks. I see under alignment "outer surface, main layer outside, wall center, main layer inside, inner surface" ... but I want a specific distance. In my case, 7/8" from the outer face of the 2 x 6 stud / sill ... or 1" from the inside of the stud / sill to the inside face of the block (both the same as the "real" block measurement is 3 5/8"). 2) is there a way of adding a layer between the upper and lower wall? I want a custom sill 7/16" wider (5 15/16 pressure treated sill) than the sill that is part of the wall (the wall will be built then stood up and attached to this). Thanks .... Mike Link to comment Share on other sites More sharing options...
xtal_01 Posted June 3, 2020 Author Share Posted June 3, 2020 Thanks! Just made the 1" gap "air" ... worked great! Link to comment Share on other sites More sharing options...
