Glass House View Rendering Error
GCCISarah
Hi everyone-
In the last several plans I have created in chief, using the reference display in a 3D view (referencing an as-built plan overlayed onto the remodel plan) with Glass House View, the Glass House View is very transparent, with no 'outlines' around the items in the drawing.
It makes it quite hard to see what the existing vs. remodel.
Any thoughts on what setting I might be able to change to get the 'outlines' back. I'll attach a photo of a kitchen I'm working on currently below, showing how faint the Glass House View is, vs. an example photo from Chief I found online, which has the desired 'outlines' in black.
This does ONLY happen when I'm using Glass House View as a *Reference Display* on the referenced plan. If I were to delete the reference display plan, and just change the rendering technique of the Plan file I'm working on to Glass House, there is no problem. The 'outlines' show as desired.
image.thumb.png.889521ecb49035edff166a08eafd9ff4.pngimage.thumb.png.34f41193102d77376be3d33704822cee.png
