Richie_Rich Posted July 9, 2019 Share Posted July 9, 2019 I'm sure this is an easy answer for most of you (or at least I hope so anyway). Is there a way to either create or make an existing symbol attachable with the electrical connection command? There are times I use a symbol in the chief library (that is an electrical symbol) that won't make a connection with this command. I'm guessing I just need to check a box somewhere? Thanks in Advance for your time! Link to comment Share on other sites More sharing options...
