How do I create a large sliding door with a corner system no post? I can find window training videos but nothing about the sliding doors.
Any direction is helpful!
Thank you
Chief X11
Shoal Exterior 052319.plan
With X11 there are some other options as well. Don't have time to make a video, but here's a quick example plan using only parametric objects (walls, windows, and doors)...no custom symbols necessary...
Corner door.plan
The main keys are to:
Use a second set of walls
Offset the doors
Just check out my settings and see if you can figger it out.
