I was looking for a way to change the direction my floors are running in the kitchen. I have a room that is separated by a line divider rather than a wall. When I apply a wood floor the direction that the floor runs is not the way that I would like it to run, any way that I can change the way the pattern runs and turn it 90 degrees ?
thanks in advance
bret
Hey Bret. Do you mean what the hey-ho is goin on?
Here's what you are seeing. I basically created a
herringbone pattern made up of dozens of Rectangular
Polylines 4" x 40". Used Transform Replicate and Multiple
Copy operations to fill out the pattern. Then converted the
Polylines to Polyline Solids 1/4" thick. Put 4 walls around
the P-Solids to form a room and Edited the Floor Finish to
0" to eliminate the room generated floor. Now you have a
floor where e
