Hi all,
I'm new to Cheif architect, and hoping for a little help!
I'm trying to create a herringbone pattern on my kitchen backsplash.
I've already changed the pattern on the copy of a tile material from the core catalog, but it doen't show up in the 3d view or on the teapot as a herringbone pattern???!!!
am I doing something wrong? how do I get this herringbone effect?
Thanks,
Sima
CA X8
Not for the faint of heart but a person could use polyline solids or material regions to create the tiles or grout or both. It's not that bad if you're used to the process, but otherwise it can be pretty time-consuming. You can use distributed objects, multiple copy, and transform/replicate among other things to speed the process up but it definitely takes a little work no matter what you do. Cool thing is that you can create some very unique and realistic tile layouts with the ability to q
