Currently have the setup below in my sig but seeing how getting new stuff is an irresistible force that I cannot seem to overcome I was thinking of getting a M.2 NVMe drive to speed things up. I currently have about 140 Gb free on my current 1 TB SSD drive and thought that a 2 TB M2 drive (which would replace my current SSD drive) would be the way to go . Then I got to thinking that A 1TB M2 drive along with the older SSD drive would give me plenty of space if the files were divided between the
A quick update to the new hard drive install. For the most part very, very good and well worth the cost and effort but (you knew there was going to be a but didn't you) when Chief reaches a certain size and complexity no fast hard drive, CPU or fast GPU will fix the 'crawl' that those complex plans revert to. I have a plan now that takes 18 seconds between every change to any component. I'll post another thread seeing if it can be 'fixed' as it has become unworkable, no matter the speed of a har
