HOW DO I "SAVE-AS" PLAN 'A' AND LAYOUT 'A', SO THAT I END UP WITH PLAN 'B' AND LAYOUT 'B', AND EVERYTHING IN LAYOUT 'B' IS ASSOCIATED CORRECTLY TO PLAN 'B, AND EVERYTHING IN LAYOUT 'A' REMAINS ASSOCIATED WITH PLAN 'A'?
THANK YOU
JIM SOHOLT
Just a quick Power Tip here...
If you're trying to save old plan iterations but keep the layout linked to the current version, I would skip the re-linking process until absolutely necessary. Just print each layout version to PDF for future reference. When moving to a new plan iteration, Save As to give the plan a new name ("Smith Residence Prelim 1" for example) but keep the current version using its original name ("Smith Residence Main" for example). This way your current layout
