My plans examiners almost always miss my surface mount CO Alarms. Is is possible to make the text "CO" bigger (maybe match the size of outlets, switches)?
Thanks!
co alarm.pdf
Yes that is an issue that can be fixed. Go to Cad Block Management and insert the cad block into your plan and explode the block. Edit to your liking and re block then rename and assign to the symbol as 2D cad block in Symbol DBX.
