Deck blocking visible on exterior of band joist
Skip_D
Go to solution Solved by Skip_D,
Hi All,
I can't figure this one out.  The deck blocking is visible on the exterior side of the band joist.  Ironically there is no blocking w/in the deck framing so I'm not sure why it's there in the 1st place.  I'd like to eliminate it.  Suggestions?  I've attached a file but I'm not sure it's in a usable format, let me know if not.
thanks,
Skip
X8
From your screen shot it looks like you are already in your Framing Layer set so if you are happy with all the rest of the deck framing then turn off auto rebuild and select and move or delete blocking.  Or attach plan file for professional help.
Hi Skip,  Great looking plan!  I fixed the blocking for you manually as you may want some there to stiffen things up and attach the railing. You can still delete if you like as I turned off auto frame for you. The only other problem I saw with a quick look was an attic wall in the Garage, if you need help with that just let me know.
Herwig 6.3 deck fix.plan
