Issue printing layouts / stretched and compressed
Migaloo
Go to solution Solved by Migaloo,
Jim:
you will probably have to post the plan and layout
otherwise, everyone is just guessing
does your drawing sheet match the layout size ?
MENU - FILE - PRINT - DRAWING SHEET
are you printing to PDF first ?
if not, you should
Lew
I am not printing to pdf. I have been printing to printer for several years with no issues. I recently had to reload os on computer and this is first time I have tried to print since the reload.
Jim:
yes, but if you save the PDF you will have an archive of exactly what was printed at that time
you can also email the PDF to others including the print shop
I also use PDF's to capture web sites for archiving or reading later
PDF can be printed in color - then when sending to printer
you can choose color or B/W
you can choose exactly which pages to print
using PDF's eliminates most printer driver issues
Lew
