Changing the dimensions settings to centerline doors & windows
DCB123
Can anyone help me find where to change the default dimensions settings in CA X8
so that it dimensions to the centerline of the doors and windows and not the edge or the exterior?
Please feel free to text me an answer as well. (970)987-4476 DCB
Thanks in advance.
  • 5 years later...
2 minutes ago, risutto said:
Thanks Chopsaw. I've made this change, but the display of my automatic dimensions did not change. (Perhaps I only changed the default settings, not the current settings for the walls in question?)
Yes I believe that is true.  Dimensions defaults do not change what an existing dimensions will locate but if you set the correct default a new dimension should follow the new default.
