Concrete Structure Software
NewAsia
Hello Everybody!
I'm searching a concrete structure analysis & Design Software which can transfer to Chief. I build structure (beam, floor, post, stair, roof...) in Chief (beam, post in general size), then I could export the tructure to import to that software. After structure software's analysing & design, I could import back to Chief. If structure software as a plugin is absolutely the best.
Anyone can give me an advice?
Or which concrete Struture Software I should use?
Thank you!
NewAsia:
Sorry, but Chief is not setup to share via BIM
you may be able to do import and export transfers
but there will probably be data loss of various types
probably best to contact CA's sales dept to discuss your needs
Lew
