change or override default wall height
Don_Straub_Const
I am using Joe's method to build a shower. I have created a pony wall glass with 6" curb, Made the door it is great.
Where i am having trouble is I can not turn off the use default wall height radius buttons in the object properties, so my wall goes to the top.  How do I enter my wall height? I am using X8
Those options will become available once you change the wall top or bottom height from the default.
The easiest way to do that is drag the wall down in a section/elevation view.
Or use the temp height dimension if you want accuracy.
