Anyone having file management issues using X8 with Windows 10?
anne_CA
My computer decided to upgrade me to Windows 10 and now files are not showing the last modified date in the filelist. If I open the file, the changes I made are there, but the date doesn't change. If I go to the Archives folder, I find the modified plan file with the correct date. I don't know if this is a quirk with Windows 10 or X8, but it is extremely frustrating. It gives the false impression that your work has not been saved to the file. Clicking the Save icon in the plan file saves the changes, but does not change the date. If I do a Save as and change the name of the file, that works, because it is a different filename, but if I do the Save as without renaming the file, the date does not update.
Thanks for your help!
Are you sure you're looking at the "Date Modified"?  Windows Explorer has about 10 different items you could potentially have displayed that show "Date _____" including; plain old "Date", "Date Created", "Date Accessed", etc...
To make sure, you can right click up in the column header area...
