Shed dormer help
mountaineer
Go to solution Solved by DavidJPotter,
I'm struggling with how to connect room walls to my shed dormer walls.  I don't know if I need to change wall type?  Any input is greatly appreciated.  I'm a rookie user still navigating my way through.  I've attached the plan I'm working on.  I know there are a lot of things that need corrected on this plan but so far I'm stuck on the second floor.
Chief Shed Dormer Problem.plan
I looked at your plan file and what happens is when you attach the shed roof, it destroys the dormer, so like Javatom said, the solution is to explode the dormer and then manually attach the shed roof around the edges of the dormer. A default dormer object is not programmed to cross two roof planes, you have to manually shape the roof plane edges to allow the dormer to stay.
