Elevation View of Closet
DCortes
One thing I am unable to accomplish is I have a closet in which I installed about 4 shelves and they are visible via camera view but not in wall elevation view.  I want to be able to show then in the elevation view so I can dimension them for review.  Anyone know a way this can be done.
Thanks in advance
Yep tried it all.  They are located in the Millwork layer and that's on I tried doorway and still cannot see the shelves.  Only in camera view.  Using wall elevation view and still no shelves.  Oh well I just went into the elevation view and drawn them in manually.
Do you realize there are 3 entirely different layer sets you are using? Changing the display while in plan view won't fix your problem (i.e just because the layer is on in plan doesn't mean it's on in your camera view layer set or section view layer set. if you attach a plan you'll probably get an accurate answer.
