Wall not going to roofline
DCaplan
Wall edges are defined by what is called a "Wall poly line". When selected the wall poly line will show "handles" that can be edited and to reshape the wall. You use this to fill any holes or anomalies like what you are showing. Another way is to go to the "Attic Level" (<A>) of your model and then manually draw in the missing attic wall segments. Whenever something is wrong there is always something you can do about it.
