Dimension lines styles
johnny
Is there a way to have the line segments for dimension different styles? So far I haven't been able to mix styles for the extensions vs dimension lines.  I'd like the lines meeting the sides/objects etc appear in a dash format but solid for the actual dimension.
Quick follow up.  I was away from my computer when I made that last post.  I tested that idea out when I got back to the office though.  It definitely works but its also definitely a bit of a PITA.  Not worth it IMO.  Having said that, I still think its the fastest option we currently have.  I believe every other option would require even more work.
Thanks for the input - too bad this is so difficult.  I realize its a minor thing, but when you have lots of cross lines it begins looking odd.  I've tried placing lines but then you lose edit-ability on those lines (lose connection).
