Depth of window interior mullion
rlackore
Robert,
Is this getting close to what you want to control.
In this pic, the mullion depth is exaggerated, but I can easily make it them any depth you want.
This is only using the window parameters.
Glenn, I would be interested in learning how you do that. Do you have time to do a quick vid.
Michael,
I am not sure what technique you are talking about in post #20 - it could be the same.
Probably easier if I just post the plan and you can look at all the setting, although I am not sure of all the options you want or need.
you can change the mullion depth by using the Mullion Depth...Inside setting.
A setting of zero will bring the mullions out to the inside face of the wall.
A setting of 3 will take them about half way.
A setting of 5 will make them very small.
Glenns mullions.plan
Michael,
Gotcha.  Your method was very similar to mine except that instead of making the frame really shallow I just removed it entirely.  Same basic idea though.
Glen and Michael,
I appreciate the help. It's a clever method, but I'm not sure it's worth having an accurate mullion depth if I lose the frame in both plan and 3D view. Creating symbols out of every window group (again, I have 63), is just too time consuming. I'm going to leave my request in the Suggestion forum because I feel it's an issue that Chief should address.
Thank you.
Michael,
Thanks Glenn
