Attic walls
mountaineer
I'm having trouble with my second floor exterior walls when I do a story and 1/2 plan using a loft with railing. When I raise the ceiling height and apply the railing it leaves holes on both sides.  Can anyone suggest a video that explains this?  I've attached the plan I'm working on.  Thanks in advance for any input. I'm using x7 on a mac.
If this is the problem you're referring to:
...just think about it for a moment. Clearly you can't have the loft railing extending beyond the roof line, right? You'll need to stop the railing wall short of the roof plane. There are a lot of other issues that should be cleaned up, such as aligning the second floor walls with those below, closing the second floor by making the north wall a Room Definition wall, etc.
