Split Floorplan
Heisenberg
I looked at your plan but from the wording of your post above, I haven't a clue what the problems are. You need to be a little more specific than "...I can get the cantilever to work" (I haven't a clue what you mean by that). Also how is the lower foundation "not working...". You need to clearly state exactly what is wrong and why it is wrong in your opinion, leaving us to guess at what you mean is an unfriendly way to treat us.
Sorry, had to post it very quick.
Issue 1: See attached picture. Wall will not generate correctly (displayed as gap)  unless I pull wall B out...
Issue 2:
Shared foundation wall is too high and side and rear pony walls will not generate... Why? See picture two.
