Sending elevations to layout
lenzom
Hi, i am trying to send my elevations to layout, but i keep getting a message
"cannot mix imperial & metric units in a layout page. All plans views sent to a layout
must be in the same units".
I have checked everything and can't find the problem.
Can somebody explain to me whats going on?
Lenzom
I suspect you are changing the dimensions using the global setting. You likely need to only set the individual dimension. Must say that having different dimension formats in the same layout could lead to confusion. I do have some clients that ask for this, I generate a separate layout, never mix the two.
Graham
