Unable to perform photon mapping
snowseals
I get the following error when trying to preview how a ray-trace of material would look like:
http://i66.tinypic.com/14nmdg6.png
When I open a sample plan like Singleton Future Home, it all works well.
I already searched for this problem on the forums and somebody mentioned the terrain perimeter was set too large.
I redefined the perimeter which is quite small now, I assume (37020mm).
Though, still no good.
When I just raytrace through a camera-view it all works.
It's only happening when previewing a raytraced view, using the Adjust Material Definition.
Attached is my plan.
Tuinhuis from scratch v5.zip
Here's how I do it:
- I set a full camera view
- I select Adjust Material Definition
- I select a table for example (which has a default Blonde Birch Material applied to it)
- I select Properties and change the Material Class, for ex.
- I select Show Ray Trace View
Note:
When I set it to Default Exterior View i dont get the error-message, but it looks strange like this:
http://i63.tinypic.com/20jimmf.jpg
I found the bug, I think!  :)
When creating a new plan, I get the same error.
Reinstalled, cleaned programdata, appdata, etc. but still same issue.
So when I create a new plan in Imperial Units (Profile.plan), all works well.
But when I create a new plan in Metric Units (ProfileM.plan) the error pops up when trying the raytrace-preview + The default ext. raytrace is looking weird, as shown in previous post.  :o
Do you guys have these same results?
- to create a new plan in Metric Units, hit Edit, Preferences, under General, New Plans, choose Metric Units, hit OK and create a new Plan
- draw a Straight Exterior Wall in square-shape, place a camera inside, select the Adjust Material Definition and click a wall for ex;
- toggle between Standard view and Ray trace view / also try to toggle between Default Exterior and Interior Ray Trace
  • 1 month later...
