Missing Floor
Chris50
I did a forum search, and Glen Woodward had the answer:
"The blank floor areas are usually caused by the Build Platform To setting in the wall def dbx.
There should be no reason why you can't use that wall def, as long as the above settIng is set to the correct wall layer."
Change the setting to layer 5 (you're main layer):
It is the main level floor. The tornado would have to have taken the floor and left the house. I have seen lots of tornados here but not that one yet.
OK, I thought you were saying the 2nd Floor was missing, not the Walls surrounding the 1st Floor Structure.
You need to delete the Foundation and rebuild it with the "Hang 1st Floor Platform Inside Foundation Walls" CHECKED
Joe, I think he's planning on bearing the floor joists on a plate. Here's a section thru his plan:
