Roof Material Default not showing properly
HomesByDesign
Go to solution Solved by HomesByDesign,
My default roofing material is a simple asphalt shingle but when I make a roof it defaults to a gray tin roof as shown on the left of the attached image - the right side of the image I changed to show you what the default is set to,,,,
Somewhere along the way I changed a setting the ignores the roofing material default (you can't even see "roofing material" on the DDB also attached),,, using the painter tool is a solution but not what I want - I want the default to take hold...
Thanks in advance...
Ron - x8
